Sponsored by: CARiD
Advice needed p0442
Old Apr 7, 2018 | 09:31 AM
T5174's Avatar
Default Advice needed p0442
02 D2 se7 with 163,665 miles
I have had this p0442 code for a while now. I just built a homemade evap smoke tester and used it today. I found smoke coming out from this square shaped canister that is behind the coolant overflow and it has a 2 wire plug and a fairly large hard plastic hose on one side. My question(s) is what is it called and is it supposed to be leaking smoke/vapor? Do I need to block the flow for smoke test?
initial smoke test I did last night showed no signs of leak except at the part in my pic.
Old Apr 7, 2018 | 12:12 PM
Best4x4's Avatar
As I posted in another thread you can get a replacement for 20-25.00 for a 99 Chevy Express Van 3500.
Old Apr 7, 2018 | 12:36 PM
T5174's Avatar
That really doesn't help me or answer my question. I do all the work and actually like learning about the components of my truck,not just through money at it and hope that fixed it.
Old Apr 8, 2018 | 10:06 AM
CamelChad's Avatar
That's #WTY000020. Its the solenoid charcoal canister vent valve. It apparently does this:
The charcoal canister is filled with activated carbon pellets that can absorb the fuel vapors. When the engine is running, the fuel vapors are purged from the canister and burned in the engine. The vent control valve (solenoid), or simply vent valve controls the flow of outside air in and out of the charcoal canister.
Sorry, but I can't really speak to whether they should smoke or not during a test.
Atlantic British has it, but I'd check out the salvage yard or ebay first. Looks to be $$$.
Chad
Old Apr 8, 2018 | 04:36 PM
T5174's Avatar
Chad
thank you for some insight into what I'm working with.
Old Apr 8, 2018 | 05:13 PM
CamelChad's Avatar
Looks like the GM part no. is #25950499
Old Apr 10, 2018 | 09:48 PM
Best4x4's Avatar
I fully answered your ? in the other thread on this subject. You've got like 3 active threads going so kinda hard to keep up.
P0442 is that normally that valve, no I haven't smoke tested a 99-02 with that purge canister, but I have fixed the P0442 fault by replacing that part. These trucks aren't getting any newer, so you'll be tossing parts at it sooner or later, just the nature of the beast.
https://www.rockauto.com/en/moreinfo...353259&jsn=460
12.95 from Rock Auto
Old Apr 11, 2018 | 06:49 AM
T5174's Avatar
I have 3 threads going because the only answer I can get from a forum for this truck and by supposed mechanics and enthusiasts, is to just throw a part at it?
as I responded to you before,I need technical help. Not someone telling me repeatedly to just replace the part. But thanks for junking up my thread again
Old Apr 11, 2018 | 07:45 AM
Best4x4's Avatar
Good Luck
phidelt583
Aug 27, 2018 01:24 AM
bsrang
Sep 3, 2008 06:12 PM
bsrang
Aug 21, 2008 08:12 AM
oraquest
Jul 25, 2008 09:13 PM
samue23
Jun 11, 2007 07:11 PM
