Sponsored by: CARiD
again?? this time its the radio
Old Aug 26, 2008 | 06:21 PM
domyo's Avatar
8th Gear
Default again?? this time its the radio
wow, I seem to have the worst luck around...
ANYWAY, as I was driving home from work today, the switch on my steering wheel to control my radio's volume, etc. just snapped.
I didn't put any pressure on it,nor did it get caught on my sleeve,my radio just went haywire! Before I knew what was goingon, the volumewent up ALL THE WAY.Then, the radio station changed and it kept switching from "tape" to "FM" to "Scan." Everytime It went back to the FM, it was also scanning through the stations superfast. All the while, I was driving. I tried turning the radio off via the main dashboard control panel as well, and It seems as if the whole thing is disabled. (meaning, NONE of the buttons work)
I called LR North America, as well as the closest dealership which happens to be 150+ miles away. (go figure) Neither of them helped whatsoever. In-fact they were quite RUDE!
So I calledNational Highway Traffic SafetyAssociation(NHTSA) and filed a safety complaint.
If anyone knows what I can do, I'd appreciate it. The radio will not turn off, nor lower its volume, or even ejectmy tape adapterfrom the tape player.
the volume is too much to drive with. My speakers are going to blow!Will pulling a fuse get it to stop??
Old Aug 26, 2008 | 07:34 PM
roverguy7's Avatar
Default RE: again?? this time its the radio
pulling a fuse will turn the radio off... however it sounds like you have a short in the wiring for the steering wheel switches, when these are in use, itll cancell out the actual radio controls, take it somewhere and have then pull your airbag off and check the wiring in there... if they dont find anything disconnect the switches, connector is behind the airbag, and see if you can controll it from the radio then
Old Aug 26, 2008 | 08:51 PM
domyo's Avatar
8th Gear
Ok I got the volume to turn down after messing with it. Andthanks for explaining why the radio controls won't work. It makes complete sense.
I'll try to find someone that will help me outwith this, butthe fact of the matter is thatno one in this stupid city is willing to look at land rovers. Everyone I've taken it to says that they are too expensive and too confusing.
Its pretty moderately ridiculous. Do you think I could do it myself somehow?
My dads friend is going to take a look at things, and he's helped me in the past, but removing the airbag isanother story.
Old Aug 27, 2008 | 06:26 PM
roverguy7's Avatar
takin the airbag off isnt bad... just make sure to disconnect the batt and wait at least 10 minutes before messing with it. 2 t30s hold it on, need to turn the wheel to get them out, once its off everythings right there
zeroone
May 24, 2015 08:21 AM
kenjisnocon
Jun 16, 2009 06:28 PM
grussell
May 24, 2009 09:00 PM
llPANCHOll
Feb 26, 2009 07:32 AM
