Its developed a thirst for coolant. Again.
Old May 15, 2015 | 09:48 AM
zeroone's Avatar
Default Its developed a thirst for coolant. Again.
Past 2 weeks. 2 maybe 3 cups of coolant. It's not on the ground, not on the passenger side floor, it's not blowing past the pressure cap, at temperature I can still squeeze the hoses, not in the oil either. I have not had time to pull the plugs and check the combustion chambers for steam cleaning or to run the liquid tester. HGs where done 2-3000 miles ago. I do get the occasional pending 304 code, it has gone hard code once in the past 2 weeks.
Any other suggestions?
Old May 15, 2015 | 11:53 AM
mln01's Avatar
Is there any sign of coolant on the left-hand side valve cover under the throttle body heater?
Old May 15, 2015 | 01:39 PM
acamato's Avatar
Get a pressure tester and see if the system holds pressure.
Old May 15, 2015 | 03:23 PM
zeroone's Avatar
TB heater is dry as a bone. Pressure test shows nothing. Cyl 4 is wet and clean. figures. Yet, the plug looks normal and shows no signs coolant. It's never been overheated... so I'm kinda at a loss.
Old May 15, 2015 | 05:24 PM
drowssap's Avatar
If #4 is cleaner than the others it being cleaned, seeing your thrist for coolant, i would guess steam cleaned.
Old May 15, 2015 | 06:06 PM
zeroone's Avatar
Nope. Dry As a bone. Cyl4 is wet though. Not steam cleaned yet, but wet.
Old May 16, 2015 | 08:50 AM
zeroone's Avatar
Exactly. It's in progress. Just need to figure out how it's getting in there.
I figure something cracked, a liner slipped, or the headgasket gave out. I have no clue. That's just off the cuff. The little woman is trying to convince me not to fix it and just trade it in.
Old May 16, 2015 | 10:11 AM
drowssap's Avatar
Remove the upper intake and rocker cover and retorque those 4 bolts, what have you got to lose at this point? A couple hours and a little black RTV?
Old May 16, 2015 | 05:18 PM
zeroone's Avatar
You have a point. I'll order a new upper plenum gasket.
Now for the dumb question... how can coolant make its way into cyl4 via the intake manifold? I don't remember what the mating surfaces and ports look like... only reason I ask.
Thanks a bunch!
Old May 16, 2015 | 08:54 PM
ihscouts's Avatar
It doesn't. The only way coolant gets to #4 is around the liner or cracked block at a head bolt. The middle two cylinders are siamesed, coolant doesn't enter heads, no ports. It flows through the block around these two on both sides of block.
