AHHHH!!! 98 disco
RE: AHHHH!!! 98 disco
Did the smoke came out of the exhaust pipes? Engine smoke could be caused by several things. It could be transmission fluid, I suggest you clean your engine by using an engine cleaner to be able to pinpoint where the fluid comes from. Other car parts to check would be your serpentine belt and head gasket as the former maybe broken and the latter maybe leaking. If you experience rough running or overheating then address it immediately as your engine could be destroyed.
