Sponsored by: CARiD
AHHHH!!! 98 disco
Old Mar 5, 2008 | 11:42 AM
herblatham's Avatar
Default AHHHH!!! 98 disco
I was just driving it, put it in reverse, and the engine started smoking?!?!?! what's going on. I thought i saw smoke this morning when i put it in reverse, and i def. saw it just now.
Old Mar 14, 2008 | 08:26 PM
kylle08's Avatar
Default RE: AHHHH!!! 98 disco
Did the smoke came out of the exhaust pipes? Engine smoke could be caused by several things. It could be transmission fluid, I suggest you clean your engine by using an engine cleaner to be able to pinpoint where the fluid comes from. Other car parts to check would be your serpentine belt and head gasket as the former maybe broken and the latter maybe leaking. If you experience rough running or overheating then address it immediately as your engine could be destroyed.
Old Mar 14, 2008 | 09:21 PM
You really need to give us alot more information then that.Manual or automatic, what color smoke, white or grey.
Have you even opened the hood to look yet?
Give us something to work with.
Qtiep
Feb 13, 2019 06:46 PM
tweakrover
Aug 24, 2011 12:27 PM
mbquimby
Mar 29, 2011 05:34 PM
