Sponsored by: CARiD
alluminum rockers vs steel ?
Old Sep 27, 2010 | 09:13 PM
XCELLER8's Avatar
Default alluminum rockers vs steel ?
I notice that several suppliers offer steel valve rocker arms as well as the alluminum ones....does anyone know if the steel ones were ever standard equipment ? I've had a couple of the newer alluminum ones have the pushrod "socket" get loose and they really make a loud racket, I would considder buying a set of steel ones to avoid the noise as well as the repair frequency, as always your thoughts are appreciated.
Old Sep 29, 2010 | 07:51 AM
The normal noise maker is the push rod, that tends to wear down, become shorter and that will then make a constant lifter type noise.
As long as Rover has been building this engine, I believe they have used aluminum, GM may have use metal on the early engines back in the 60's.
clint70
Dec 9, 2014 04:20 PM
racerxnet
Engine & Internal
21
Mar 10, 2013 09:28 PM
ralphobell
May 18, 2012 07:10 AM
kpl1228
Nov 20, 2010 11:05 PM
cobbcj7
Nov 13, 2009 07:41 PM
