Sponsored by: CARiD
Alternator install problem.....
Old Aug 27, 2019 | 06:53 PM
Wrench's Avatar
Default Alternator install problem.....
2006 LR3 4.4
Installing a new alternator. Power connection on, wire harness plug popped right in. Now for the last 5 HOURS I'm struggling HUGE trying to get the 3 bolts in.
Got the bottom two started but can't for the life of me get the top one started. So I'm starting over in the morning. Does anyone have a tip or trick or...? Frustrated.
Thanks!
Old Aug 28, 2019 | 08:00 AM
Wrench's Avatar
Hmmm crickets.... I hope to answer my own question this morning. I "think" the problem I am having (lining up the bolts) is due to the power cable interfering with movement. I'll disconnect it and move it away. Reconnect after starting the bolts. Hope this works...
Old Aug 28, 2019 | 10:31 AM
Wrench's Avatar
Yep...That was it. Leave the power cable off until the bolts are run in. Never picked that up on the videos I seen.
Old Sep 12, 2019 | 07:15 PM
delormea397's Avatar
Hey glad you were able to figure it out. I found this same problem when I replaced my alternator. The power cable is stiff and has a certain shape to it. It makes it difficult to manipulate the alternator in to place properly to run the bolts in.
BLee
Sep 6, 2011 02:23 PM
willmjck
Dec 29, 2010 08:38 PM
jlgolson
Jan 14, 2010 07:56 PM
masism
Jun 1, 2009 08:48 PM
autocckr2
May 4, 2008 12:36 PM
