Sponsored by: CARiD
another disco II overheating
Old Jun 19, 2008 | 09:18 PM
raedmonson's Avatar
Default another disco II overheating
I have a 2001 discovery II that started overheating yesterday. It appears that the water is pushing back into the bottle and flowing out the over flow hose. I put about a gallon and half of water back in and started it up and once it got warm the water started boiling back in the bottle and I immediately cut the engine offand let it cool down.I noticed that with the heater on hi thatthe air was cool.
I have completed the first step and that is not to run or drive it until I figure out the problem. I plan to have it towed to my mechanic but I was wondering if anyone thinks the thermostat may be stuck? I guess it could be several things but I am trying to be optinistic. Also, is the thermostat behind the alternator and air compresser (the long metal pipe)?
Thanks,
Randy
Old Jun 20, 2008 | 07:12 AM
Default RE: another disco II overheating
Since you have a cold heater you have a lot of air trapped in the engine's coolant system. What led up to this, have you been having to add coolant?
Old Jun 21, 2008 | 07:13 AM
raedmonson's Avatar
Yes Mike, I have had to add some coolant from time to time. There have been a few times that I have noticed a puddle on the groundunder the passenger side of the vehicle and it was a big puddle. Is there a way to id if a head gasket has gone bad, visibly or do you have to do a leak test? How do you remove the air from the system?
Old Jun 21, 2008 | 07:18 AM
Go have a shop do a coolant pressure test to find the leak.
PM me your tele number and a good time for me to call you.
I wouldn't drive it till we talk or you get it fixed.
Old Jun 29, 2008 | 07:06 AM
LrTECH's Avatar
Sounds like you need an engine
SSL9000J
Feb 28, 2013 12:46 AM
bambi851
Jan 12, 2013 05:15 PM
Stokkies Theron
Nov 5, 2012 07:35 AM
TheyseemeRovin'
Feb 22, 2012 05:24 PM
msm15
Jan 16, 2011 04:42 PM
