Sponsored by: CARiD
Arb ???
Old Oct 12, 2010 | 02:58 PM
Long Haul's Avatar
Default Arb ???
Ok I installed a new set of ARB lockers this weekend and the dont come unlocked quikly is this normal or did I mess something up when I installed. It takes about 5 seconds to unlock. Im using arb compressor with arb solenoids and air lines if that helps.
Thanks in advance!!
Old Oct 13, 2010 | 07:44 AM
5 seconds while sitting or driving.
Most likely normal if just sitting and probably not too unusual even when driving, pressure just isn't bleeding down real fast.
Old Oct 13, 2010 | 07:27 PM
Long Haul's Avatar
It takes about 5 seconds while moving. I can hear the air releasing from the solenoids as soon as i flip the switch but they seem to stay locked for about 5 seconds or so after word. I tried backing up, turning, forward it seems the same no matter what i try
Old Oct 15, 2010 | 07:14 AM
lordmorpheus's Avatar
Originally Posted by LAKEL.AMBERT
The standard practice in checking the coolant level it to view the expansion tank. If this is how you arrived at the "coolant level seems okay" then Check the radiator level when cold - NOT the expansion tank.
I had no idea air lockers were water cooled...
Mods: Feel free to delete this post when the spam is deleted
Old Oct 16, 2010 | 05:50 AM
Range Rover Blues's Avatar
Mine are well used and they come out straight away. See how they go for a while.
Depending on what you are doing at the time it shouldn't be a problem should it?
BTW if there is any wind up in the diff at all they might not unlock.
Old Oct 17, 2010 | 08:17 AM
Long Haul's Avatar
Well I changed my oil after breaking in my new gears and the lockers are getting a little faster now. I guess they just needed loosend up a little.
DiscoRover007
Aug 14, 2015 11:46 AM
ajh
Oct 10, 2007 10:16 PM
uziduzit
Aug 17, 2007 09:08 PM
ABWsRover
Jul 11, 2007 11:18 AM
2003Disco2
Dec 8, 2006 05:15 PM
