Sponsored by: CARiD
auto shift knob
Old Jul 1, 2005 | 11:37 PM
razorbak's Avatar
Default auto shift ****
1997 Disco....how do I remove the automatic shift ****?? My $70 workshop manual doesn't want to tell me.
Thanks, Al
Old Jul 2, 2005 | 10:38 PM
Bene's Avatar
Default RE: auto shift ****
as i recall, you pop off the center peice and there's a screw or bold under that.
Old Jul 3, 2005 | 01:55 AM
Bait's Avatar
Like Bene said, pop the cover off and there is a clip that you must remove. Then unscrew the large nut and pull hard to remove.
Old Jul 3, 2005 | 02:05 PM
razorbak's Avatar
Thanks for the help!
Old Oct 3, 2020 | 05:04 PM
Art54Williams's Avatar
4wd High
Question 01/98 Land Rover Discovery 1
I do NOT have a plastic top cover to remove on the shifter ****, only a driver side push button on the shifter. I need only to repair the shifters lights. Do I need to remove the shifter or will the light /shifter indicator panel allow me to change lamps with a sub removal with wiggle room?
Old Oct 5, 2020 | 02:41 PM
WaltNYC's Avatar
remove the rectangle shaped surround at the bass of the unit. Remove the rubber mat. You'll see wires leading to each side of the shifter. The bulbs simply pull out and can be replaced quite easily.
Rover_Hokie
Sep 12, 2012 09:50 AM
fri3daz3
Aug 18, 2008 09:24 PM
APSIS USA
Apr 30, 2008 10:52 AM
Chrisinhouston
Nov 16, 2007 09:59 AM
martinez
Engine & Internal
Jun 3, 2007 04:47 PM
