automatic discovery overheats gearbox
A restriction in flow can do this.
Filter change needed, trans line collapse on the inside.
I have seen a cooler get almost pluged up.
Or a bad temp sensor with a false reading.
I have had pulled a small trailer(500Kg) in 100 plus(40cen) heat at 80mph(150kph) for 960 miles(1600k) stock transcooler and never ran any hotter than normal.
With the AC on.
So you have something thats making it run hot.
Bad fan, fan clutch.
With the AC on.
Where is the sending unit located for the trans temp? is it inline?
5,000 miles before my SWB tranny failed it triggered the light but it didn't make sense being on when cold, etc...
Is it possible to "clean" lines inside - or is it better to buy a roll of rubber hose and cut into the steel lines? I know it's not as good as steel.
Are there properly sized UNIVERSAL cooling lines (like the u-bend-it brake lines)? That seems to be a better answer than paying major dollar for factory...
cosmickites
Defender
09-07-2019 04:51 AM
megathunder
09-26-2014 09:36 AM
johnkbl
08-30-2007 08:43 AM
