Sponsored by: CARiD
Back windows won"t work now.
Old Sep 27, 2008 | 07:00 PM
kayaku's Avatar
Default Back windows won"t work now.
Hey, Checked both fuses on the panel of my 98 disc neither is blown, front windows work. Is their a circuit breaker somewhere? window lock not on by the way. Thanks for the help solved two problems. Love my new toy.
Old Sep 28, 2008 | 08:13 AM
Default RE: Back windows won"t work now.
Circuit board in the BECU most likely has a bad soldier or a repairable crack. Pretty common for Disco's
Old Sep 28, 2008 | 11:49 AM
kayaku's Avatar
What and where is the BECU? Thanks.
Old Sep 28, 2008 | 02:51 PM
bhorwhat's Avatar
I had the same problem with my 99 Disco two years ago. At first, the windows went down and stayed down. The next day I started the car and 'voila' back up. That afternoon, I put them down a few inches and they were stuck.
I was able to resolve the problem with a by-pass kit that Atlantic British sells for the Disco Series 1's. Its only $15 so it may worth trying yourself. Check it out at:
http://www.roverparts.com/Parts/AMR1282RK.cfm
It comes with step by step instructions and takes all of 15 minutes. The ECU for the rear windows is behind the glove box. You'll need to remove the cardboard fascia trim under as well but its very straightforward. The connections are press-fit so there's no need to solder anything.
Best of luck.
Bob
Old Sep 28, 2008 | 02:59 PM
kayaku's Avatar
Awsome! Thanks a lot. I'll remove my glove box now and check it out. The kit looks just like a wire with a harness thing. 15 bucks I think i'll just order it. Does this fix the problem forever? permanatly bypassing a faulty part?
Old Sep 28, 2008 | 06:15 PM
bhorwhat's Avatar
It fixed it permanently for me. The guys at Atlantic British can probably explain how it works. It is a by-pass of some sort. Best of luck.
Old Nov 20, 2008 | 08:33 PM
charley_bucket's Avatar
4th Gear
This thread really helped me out too!
Thanks guys!
MrHSE7
Nov 20, 2014 06:08 PM
colemtd
Nov 18, 2014 10:17 PM
rickranger
May 5, 2006 10:12 AM
rickranger
Apr 30, 2006 03:24 PM
Rovercountry
Mar 22, 2006 03:38 PM
