Sponsored by: CARiD
bad fuel leak
Old Dec 23, 2012 | 03:42 AM
brianleonard's Avatar
5th Gear
Angry bad fuel leak
Discovery II diesel 2004.
Hi Guys, looking for a bit of advice, reversing up a lane parked up and saw a trail of 12" puddles of fuel. It appears to be dripping off the tow bar but the there was a lot rain yesterday so I have stood it to dry out. It appears to only leak when the engine is running so I reckon I am pumping it out. What do I need to be looking for, rotting tank fuel conections, do I need to drop the tank. Any advice would be helpful, supposed to be doing some long haul visits this Christmas, not looking good.
Many thanks Brian
Old Dec 23, 2012 | 10:06 AM
Michael M. Koch's Avatar
Not familiar with D2s or diesels, but the RAVE manual will probably tell you where your fuel lines, filter, pump, etc. are located so you can check for the most likely leak spots. In the meantime, I would recommend not driving at all. Too risky that you might ignite some of your leaking fuel, not a good way to spend the holidays.
Old Dec 23, 2012 | 04:14 PM
Rovin4life's Avatar
04 diesels have lots of lines that leak. They are plastic and don't start fires. You need to have it checked out to see which one is leaking.
starcraft1
Nov 13, 2011 08:14 PM
JumPeR04
Apr 7, 2011 09:52 PM
oljohnboy
Sep 14, 2009 03:01 PM
rgrizzard
Mar 6, 2008 10:16 AM
Bene
ROAMING WITH FRIENDS
May 11, 2005 04:33 AM
