Sponsored by: CARiD
Belt/Pulley Noise/Chirp
Old Jul 13, 2009 | 01:44 PM
CampCobb's Avatar
Default Belt/Pulley Noise/Chirp
2000 Disco
88k miles
When engine is cold I have a chirp, chirp, chirp for about a min. or two.
Increases with RPM's and chirps parked or moving. I have narrowed it down to pulleys I believe, cause I replaced belt with new and sanded down pulleys. Noise changed a bit but is still there. tensioner seems to be fine. I used metal rod to pinpoint noise with no such luck. Any ideas? Can a perticular oil/grease be injected/sprayed behind pulleys to chance any change in noise?
Thanks for info...
Old Jul 19, 2009 | 07:47 AM
CampCobb's Avatar
with my belt off, the ACE pump pulley does not turn freely. Are these pulleys servicable without replacing ACE. First post still remains......would a grease or wd-40 be ok to spray behind pulley to locate noise?
Old Jul 19, 2009 | 09:08 AM
First, you screwed up using a spray at or on the belt. Buy a new belt, tensioner pulley and both idler pulleys and you will be fine. As for the ACE pump, there is a lot of pressure on ity and it will not spin freely.
Speaking of your ACE, when did you last service it?
Old Jul 19, 2009 | 02:42 PM
CampCobb's Avatar
ACE has never been serviced by me. I have owned it for only 1month so far.
Old Jul 19, 2009 | 05:04 PM
tastandish's Avatar
is it pretty common for the tensioner pulley to get noisy?....I am having a whine that is think is coming from that too but I really couldnt pinpoint the exact pulley that was doing it
Old Jul 19, 2009 | 09:01 PM
JavaRacer's Avatar
2001 Discovery II
I had the noisy high pitched chirping, especially noticeable when going through drive-thrus, or just sitting and idling. Not incredibly loud, but kind of embarrassing. I was at about 86,000 miles. I replaced the belt tensioner and idler pulleys. Cleared it right up!!
Old Jul 20, 2009 | 06:49 AM
So, take a look at my service list on the top of the Discovery section. This will give you a few things to do and if you get back to me I can walk your thru the Ace service also.
Delray
Dec 2, 2015 10:59 PM
zrmcdonald777
Jan 29, 2015 12:30 PM
Jared9220
Aug 20, 2014 10:22 AM
JakeVT
Oct 15, 2011 03:03 PM
mac25dm
Jan 20, 2008 06:47 PM
