Sponsored by: CARiD
bleeding the modulator
Old Dec 3, 2008 | 07:54 AM
caleb's Avatar
Default bleeding the modulator
Hello, I just off the phone with the LR service manager and he told me if i detach the brake lines from the modulator it needs to be bleed and hooked up to a test book. Is this true , i installed a shuttle valve kit the other day and was under the assumption it was plug and play and bleed the tires-and job doneis there more to the jobcaleb
Old Dec 3, 2008 | 09:02 AM
Default RE: bleeding the modulator
I believe that if you start the engine and hold the brake pedal to the floor for a little over a minute, the ABS will activate and purge it self.
Old Dec 3, 2008 | 10:23 AM
caleb's Avatar
Mike , i did not hold the pedal down when i put the shuttle kit in. i just bleed the brakes and went for a ride to do a panic stop and found out my abs is not activating. Brakes are working just abs is not. I suppose i will get that rebuilt mod you mentioned. So that hooking up to a LR computer and bleeding the mod is False?
Old Dec 3, 2008 | 11:49 AM
Get the exact codes read, then cleared and see what shows up before you trow any money at it.
Let us know what happens.
Old Dec 26, 2008 | 02:26 AM
rinmud's Avatar
Is the light on folks??? abs will reset itself once it self tests on start-up if the light isnt on then find a patch of ice and retest. scott
04duxlr
Jan 8, 2014 04:22 PM
earlyrover
Oct 3, 2013 04:16 PM
stadic
Apr 11, 2007 11:51 AM
stanigu
Jan 21, 2007 02:25 PM
rebooTT
Jun 20, 2005 01:09 AM
