Sponsored by: CARiD
Body lift for 98 disco 1
Old Dec 9, 2012 | 06:43 AM
mattdisco1's Avatar
4th Gear
Default Body lift for 98 disco 1
hi guys, im sure you have heard this a thousand times. I have a 98 disco 1 with a 2" suspenssion lift. I have recently purchased 2' body blocks and would like to know what is involved in puttimg them in. I use to own a nissan patrol and puting the body lift in was simple just had to adjust little things like radiator shroud ect ect ,would anyone exactly know what needs to be adjusted for the blocks to go in thanks matt
Old Dec 9, 2012 | 08:35 AM
hilltoppersx's Avatar
you will need risers for the seat belt mounts, support at the top of the radiator, brake line extensions, and an extension for the steering shaft (essentially a drive shaft) and front and rear bumper risers.
with only 2" lift and a 2" body lift i would worry about on-trail stability. If i were you I would look at 3" springs and 33" tires (or tyres). That's about as big as you can go without serious mods. what shocks are you running?
Old Dec 14, 2012 | 03:02 AM
mattdisco1's Avatar
4th Gear
thanks mate sorry for the late reply yer im still deciding weather to just go 3" suspension i still want to have a comfortable ride. Im not sure what shocks are in it atm as its still at the machanics
Old Dec 19, 2012 | 05:29 PM
antichrist's Avatar
A moderate suspension lift with a body lift will keep your CoG lower than a larger suspension only lift. = more stable.
Old Dec 19, 2012 | 05:59 PM
I would take the inch more in spring lift with a 3" kit and an inch less in overall height caused from a 2" lift and 2" body lift. if we were talking about a 5 inch spring lift that's a different story I would add spacers to get a wider stance rather than a 3 inch lift with 2 inch spacers. everyone has their own preferences but I'd rather have the travel and droop possibilities of shocks and springs.
SkyHigh95
Nov 11, 2010 08:29 PM
Gordon Bombay
Apr 28, 2010 11:37 PM
bubblehead5
Jan 31, 2010 05:51 AM
sharp21
Oct 21, 2006 06:54 PM
JRdisco1
Feb 10, 2006 12:34 PM
