Both back passenger windows will not go down
If anyone has had this problem or has any ideas it would be greatly appreciated!
Both my back passenger windows will not go down. I thought it was just the fuse but it wasn't. When you press either of the buttons for the window it makes no noise or any attempt to go down. Any ideas?
here is the link for anyone still looking
"Repair a Land Rover Discovery electric window ECU to make the rear windows open again"
This is driving me nuts
Ok so I took the ecu out and resolder the circuit board to try and fix my back windows so they would roll down. Well I fixed the back windows but now the front ones will not roll up. I can hear a click sound coming from the ecu and the window motor. Now what's really got me is that it clicks now even when I do not touch the window button. The window motor will click on the drivers side then click on the passanger side. Just back and forth. Also noticed that when I hit the drivers side window button it does not make a click in the ecu like the passanger side does. Now what's even worse is that it does it when the keys are not in the ignition. I have to unplug the negative battery terminal to get the clicking to stop. Does anybody have a clue to what the deal is. Please help it's very frustrating. Also heard you can hard wire the windows up but not sure how to do that.
I have an 07 Land Rover LR3. Both my rear windows will no operate with either their own switch nor the main driver door switch. not noise or anything. the light on them comes on so you can see the switch at night but that's about it. What if anything, can I do myself to fix this? I am pretty mechanically inclined so I hope it's something I can do myself. thanks for any help.
