Is this brake or diff. leak???
Do you know if this fix is an expensive one??
Re check the clip on the axle booth first , at hi rpm grease is easier to get through , check the booth again , because if you never changed the booth before , it now 8 yrs old , you did say 2007 model right ... a crack on the rib if the booth can not be detected unless its being flexed ..so it may seem good but it may not be ... the colour you are stating points to axle grease the only coloured thing in that area.... jack it up and turn the wheels check it again , clip as well,
this problem brought back memories here.....
Im probably going to have the dealership fix it...any idea of the cost???
Thanks
Under high RPM ,and the laws of gravity ,grease would be slapped around the inside of the booth forcing it to come through the smallest of hole even ...
All you need there is a new , booth , clip , and grease , the work involve to change it will be the greater cost ...
fill a balloon with some water , make a pin hole in it ,you will see drops coming of it, then swing it around over your head in circles , it sprays now doesn't it ....
don't worry about it , ( being a newbie ) every day we live ....every day we learn !!!
brandon4589
Dec 25, 2008 08:43 PM
