Brake light switch
You need a panel pulling tool.
Under the steering column and dash fuse panel is a black panel just above the brake pedals. I think there are 4 plastic panel rivets that need to be removed. Remove panel, follow brake pedal up on pedal assembly and you will hit the brake light switch, pull out and disconnect wires.
You will be amazed at how easy it was.
tibyABv6
01-07-2011 06:02 AM
angasreid
11-16-2006 11:40 AM
