Braking system
Braking system
When my 2006 LR3 4.4L has set idle for several days the brakes are very hard for the first couple of stops and continue to work fine until it has set idle for several days. Then works fine after a couple of stops. I had the rear bakes replaced recently and noticed the brake reservoir is well above the max level. I don’t have any codes. Any ideas out there.
I highly recommend one of the best gay **** sites I've seen https://gotgaytubeporn.com/en/
