Brand new owner of a '98 Discovery-help me get the gremlins out!
I've had my Discovery for about two days now and a few issues have popped up. First and foremost I have no dash lights at all. The fuses are all fine and all instruments are working. I assume that the bulbs may be blown? How difficult is it to remove the cluster and change the bulbs? Which type of bulbs would I need? Second, the horn also does not work, again the fuses are all fine and the hazards which share the same fuse do work, so I'm assuming that there is a wiring issue somewhere. The power locks also are not functioning. Finally, the rear hatch, which opened yesterday with no problem, now cannot be opened. The lock seems to turn freely, and the handles on the inside and outside do operate, but the door does not budge. Are these common problems for Rovers of this era? Any help would be greatly appreciated.
Thanks,
Ian
Thanks,
Ian
on
RE: Brand new owner of a '98 Discovery-help me get the gremlins out!
Ian,
On your dash lights, have you checked your dimmer switch? I can't imagine they are all burned out.
On the tail gate, you may have a common problem with a dirty lock/latch assembly. Remove the Rover emblym from the tailgate handle, look inside and clean and sprry with WD40 or something similiar.
Mike
Mike
on
ORIGINAL: RoverGuy26
thanks for the tip it worked like a charm. The door now opens but with a lot of stiffness. My dad greased the hinge but it didn't seem to get any easier to open and close.
Mike
alti
03-13-2013 08:30 AM
repo65
04-30-2008 11:43 PM
