Sponsored by: CARiD
Broken hood release cable in a Disco 1
Old Apr 29, 2017 | 10:03 AM
dialtonehero57's Avatar
Default Broken hood release cable in a Disco 1
We got this Disco with a vise grip on the hood release cable. When I went to check the oil two days ago the hood release finally broke off at the bracket holding the cable. There is nothing sticking out to grab to release the hood.
Anybody have any ideas to get the hood open?
Old Apr 29, 2017 | 11:10 PM
Icannap1's Avatar
You can loosen the nut behind the bracket, gain access to the remaining cable casing, get a razor knife and trim the plastic casing, then bend the casing back and fourth, then stretch the casing and clip the stretched casing it will expose the center cable, place some vise grips on the cable and pull open. once that has been done you will need to replace the hood cable assembly. Give it a shot.
Old Apr 30, 2017 | 11:00 AM
Excellant idea! Thank you for your info. I'll post up when I get the job fone🙏🏻
Old May 9, 2017 | 10:32 AM
just wanted to let you know I got the hood open with your idea. Thanks.
Old May 10, 2017 | 03:32 PM
Icannap1's Avatar
That's great. Now you can order a new hood release cable for your D1. It is very easy to install and it makes opening the hood a breeze once replaced.
Old May 11, 2017 | 05:17 PM
its already hear!
AK Rover
May 1, 2017 11:04 AM
steveo2000
Sep 8, 2015 08:00 AM
OEMPartHaus.com
Apr 8, 2015 09:01 PM
twaszak
Feb 4, 2014 04:08 PM
str82ufrme
Jul 19, 2012 04:36 AM
