A/C Compressor Question
Hey Guy's
2001 Disco II
Does anyone know, with A/C blowing on max is it normal for the compressor to be cycling on and off every few seconds or should it be running continuously
2001 Disco II
does the compressor just cycle , or does the temperature drop in the cabin to ?
if the temperature does not drop , its working normal ... when the temperature reaches to max in the cabin , the compressor cuts off , when it starts to drop it comes back on . just like when you are pulling off by a light ... its cuts off till the gear changes in the tranny...( for automatic vehicles )
UPDATE:
So I checked the condenser fan and it"s running. The ac is blow cool but not as cold as it should Pick up a can of 134A the kind with the built in gauge (see Photo) But I don't know what the correct pressue should be any suggestions. I don't want to over it fill and cause any damage.
