Sponsored by: CARiD
C0634 ECM connector grounds
Old Aug 20, 2011 | 07:51 AM
john65b's Avatar
Default C0634 ECM connector grounds
Hey all, I have ground continuity on pin 5, but pin 6 (power ground according to RAVE) does not have ground when vehicle is OFF. See attachment...the earth ground I was referencing to was a nearby chassis bolt-head.
There is no Pin 4 connected on my model - 2002 Disco II SD...
Should there be ground continuity?
Old Aug 20, 2011 | 09:17 AM
Rovin4life's Avatar
what are you actually trying to check and what is the problem?
Old Aug 20, 2011 | 10:48 AM
john65b's Avatar
Trying to see if I have a loose / intermittent ground. When troubleshooting newly replaced MAF (Lean Codes P0171 / P0174) I noticed the MAF Ground wire was a 10 - 15 ohms to chassis ground. Cleaned off the two ground tabs near fuse box and battery...but also looked at the ECM 9 pin plug CO634. Read pins 4 / 5 / 6 should be at ground.
Old Aug 20, 2011 | 06:51 PM
Rovin4life's Avatar
where did you buy the MAF sensor from and did you ask for the correct motor, vehicle, and year. Makes a big difference.
Old Aug 21, 2011 | 09:25 AM
john65b's Avatar
I cleaned off the grounds and resistance is much closer to 0 now...I bought it at British parts of Utah...original Bosch...2002 Disco 2...
Issues remain
m3dragon
Nov 9, 2015 09:23 AM
Ankeneering
Jun 11, 2014 06:24 PM
jdwilks
Dec 12, 2013 02:52 PM
JBEGIN
May 5, 2009 07:46 PM
Spike555
Aug 29, 2008 11:39 AM
