Sponsored by: CARiD
Camera Image Flipped - Side Mirror
Old Aug 2, 2023 | 08:51 AM
Keefro21's Avatar
Default Camera Image Flipped - Side Mirror
The camera image displayed on screen for my passenger side mirror is flipped vertically. I noticed a bit of a strange movement on the 360 camera view and decided to check out each of the four cameras individually (front, back, driver, passenger). The easiest way to explain it is the photo below. The wheel and tire on the passenger side is the front tire, but it appears at the back of the vehicle. I haven't had any recent repairs or damage to any part of the car. A software update from a month or so ago is the only potential cause I can think of. The physical camera looks normal under the mirror with no apparent damage or tampering. Has anyone experienced this?
I'd be relieved for someone to tell me it's User Error and I can walk away looking silly rather than taking this to a dealer! The mirror is extended, not folded up. I can't think of any other obvious things to post so I look forward to what you share with me!
Software version: 19C_19.46.4-458817
2017 Discovery HSE td6
Old Jan 14, 2025 | 04:39 AM
amg63's Avatar
Default Possible solution?
Had the same issue, happened to me after i changed the car battery.
Managed to fix the issue by removing the camera from the side mirror, starting the car, switching the car off and finally putting the camera back.
Returned back to normal, hope this helps.
Old Jan 14, 2025 | 08:19 AM
Keefro21's Avatar
Thanks for the advice! Did you find a quick way to remove the camera from the mirror? Or do I have to go through the inside of the door?
nashvegas
Jan 12, 2022 02:56 PM
Dmedenas
Jan 2, 2022 01:09 PM
Rover06
Jan 2, 2022 08:18 AM
mopadzi
Dec 18, 2021 02:34 AM
TrioLRowner
Nov 14, 2020 08:14 AM
