Sponsored by: CARiD
Cannot read error codes...
Old Jul 26, 2012 | 10:46 AM
Externet's Avatar
Default Cannot read error codes...
Hi all.
My proven good generic OBDII reader works well for General Motors vehicles and spits nothing on a 2000 Disco.
Does it take a special/different reader/protocol ?
Thanks.
Old Jul 26, 2012 | 11:11 AM
drowssap's Avatar
a generic OBDII reader should give you the basic information
Old Jul 26, 2012 | 03:12 PM
But it won't talk to some of the six other dedicated computers on the truck. You should get O2 info, coolant temp, intake air temp, and lots of other fun stuff. Are you getting anything? Does your reader power up? Inside the truck fuse 20 runs the reader socket.
ABS (SLABS) (D163)
ECU-SELF-LEVELLING/
DCU-AIRBAG (D171)
TRANSMISSION (D123)
ECU-ELECTRONIC AUTOMATIC
COMPARTMENT (P108)
FUSE BOX-ENGINE
MODULE (ECM) (D131)
ENGINE CONTROL
(BCU) (D162)
BODY CONTROL UNIT
ENHANCEMENT (ACE) (D191)
ECU-ACTIVE CORNERING
CONTROL (D121)
ECU-CRUISE
BURNING (H115)
Old Jul 27, 2012 | 10:44 AM
Externet's Avatar
Thanks.
Yes, the error code reader (cheap and simple, not a full scanner) does power up, does its own self test sequence and ends displaying no errors; and the MIL lamp is lit and when I revdup the engine to 3Krpm, it flashed for a while and back to steady on.
Does it mean that going to a non-dealer repair shop I may not get the other dedicated compfusers readings either ?
-----> Would the Ultragauge report error codes from those extra computers ?
The humble gadged I have is attached.
Old Jul 27, 2012 | 12:01 PM
Ultra Gauge just reads the basics, but the real advantage is the real time data monitoring. Your ECU could be bad, but stop at most auto parts stores and they will normally read codes for free. Some states and home offices prohibit reset or clearing of codes. Some stores even loan readers (O'Rielly near me does).
All these basic readers won't see the data from the other computers, a different type of scanner is required (advanced shop or dealer, get price for diagnostic check first).
migfran
Dec 18, 2016 01:19 PM
Joshman
Sep 28, 2012 01:36 AM
pixel
May 13, 2011 07:24 PM
ramrod24
Dec 5, 2010 08:32 PM
silver06hemic
Dec 24, 2008 10:56 AM
