Sponsored by: CARiD
Can't get out of Park?
Old Feb 1, 2007 | 12:17 PM
panther9's Avatar
5th Gear
Default Can't get out of Park?
Goodmorning, Matt here.
1998 Discovery Series I
Can't get the transmission out of park?
- Have applied brake pedal and emergency brake, shifter won't budge.
- Noticed that brake lights do not activate when pedal is pressed.
- Checked all fuses.... they are good.
- Checked fluid level.... good.
I am thinking that the pedal switch/interlock may have gone bad?
Any suggestions?
Thank you,
Matt
Old Feb 1, 2007 | 02:57 PM
Default RE: Can't get out of Park?
You need a new brake switch, easy to replace and cheap to buy, about $25.
Mike
Old Feb 1, 2007 | 03:09 PM
panther9's Avatar
5th Gear
Mike,
Yep I got that from other threads after I posted mine.
Just got back from purchasing the switch and have been trying to access the area where the switch is or I think it is.
It appears I need to remove the cover that the computer plug is integrated into to access the switches. Problem is, I can't really see or feel how to get to the switches or get the cover off?
I would sure appreciate some pointers on finding, accessing and replacing the switch?
Standing by.... and thank you for your help.
Matt
Old Feb 1, 2007 | 03:19 PM
panther9's Avatar
5th Gear
Mike,
Got the switches swapped out. Just had to be a bit forceful with the retainer clips on the cover to get them out. Everything works fine, brake lights and getting out of park.
Great forum.... I really appreciate the response and willingness to advise.
Thanks,
Matt
Old Feb 1, 2007 | 06:51 PM
Glad it worked out forr you.
Mike
goonie
Jan 30, 2015 08:52 AM
clockmaker21
Jan 7, 2010 09:20 AM
michaelh
Sep 8, 2008 08:03 AM
illuminum
Oct 8, 2007 05:34 PM
mge_1
Jul 21, 2006 01:54 AM
