Changing rim size from 19 to 18
18" rims were a option for that year so just stick with the stock size tires and you will be fine. That should be 255/60-18 if memory serves. Also keep in mind while the lug pattern is the same you cannot use Discovery 2 wheels on the LR3 due to the smaller center hub bore.
yukonridin23
09-22-2009 01:18 AM
