Sponsored by: CARiD
Changing rim size from 19 to 18
Old Aug 9, 2017 | 12:00 PM
Noah Woodcock's Avatar
Default Changing rim size from 19 to 18
What do I need to do to insure that I don't mess up the mileage computer? Get a particular tire size? Should I stick with the same width tire? I have a 2006 LR3 HSE. Thanks!
Old Aug 9, 2017 | 12:24 PM
18" rims were a option for that year so just stick with the stock size tires and you will be fine. That should be 255/60-18 if memory serves. Also keep in mind while the lug pattern is the same you cannot use Discovery 2 wheels on the LR3 due to the smaller center hub bore.
Old Aug 9, 2017 | 12:28 PM
OverRover's Avatar
You are spot on, the 255/60/18 will not cause a speedo issue.
Old Aug 9, 2017 | 12:40 PM
even a blind squirrel finds a nut from time to time lol
Old Aug 9, 2017 | 02:22 PM
Sixpack577's Avatar
Can't the ecu be reprogrammed/flashed to run different wheel/tire sizes like any other ob2 or 3 vehicle?
DonRW2007
Aug 18, 2011 10:36 AM
Classklown90
Jan 27, 2010 12:49 PM
yukonridin23
Sep 22, 2009 01:18 AM
apcollin
Tires
29
May 24, 2009 02:03 PM
rickydt
Feb 24, 2006 02:04 AM
