Sponsored by: CARiD
Check Enging light - Code 25
Old Jun 18, 2007 | 10:13 AM
DetroitRover's Avatar
Default Check Enging light - Code 25
I have a 1990 Range Rover Classic. My Check engine light is on, and the computer display under the passanger seat is displaying the number "25". Not sure where to begin. I do know for sure that I have an exhaust leak at the number 8 cylinder and need to replace the exhaust manifold on that side. Not sure if this has anything to do with it or not. Looking for suggestions to where I can begin trouble shooting this one.
Cheers,
Glenn
Old Jun 18, 2007 | 12:50 PM
Default RE: Check Enging light - Code 25
Here is some info to get you started, how old are your plugs, wires and the rotor and cap?
Mike
Code 25 - Ignition misfire
This code indicates that an ignition system misfire has been detected. Codes 40 or 50 indicate on which bank the misfire has occurred.
Code 40 - Misfire bank A - left bank
Code 50 - Misfire bank B - right bank
If both codes are displayed, check the following components common to both banks:
Distributor cap
Rotor arm
Coil
Electrical connections
Pick-up (air gap)
Amplifier
Injectors (if code 34 or 36 is displayed)
If either fault code 40 or 50 is displayed check components applicable to the particular bank that the misfire has occurred on.
Spark plugs
HT leads
Distributor cap
Injectors - if code 34 bank A or 36 bank B displayed
Old Jun 19, 2007 | 09:24 AM
Thanks Mike. My Plugs, wires, cap and rotor are 12K miles old. Just checked them all, and are very clean. The code only displays the number 25, and does not show a 40 or 50. Should it cycle through more numbers if there are more then one codes present on the computer?
Cheers.
Glenn
Old Jun 19, 2007 | 11:14 AM
Try this out.
Mike
Engine Fault Codes
Note: This information is for the 4.0 liter V-8 OBD I (On Board Diagnostics, phase I) Petrol engine that is found in the US. The information may hold for other markets and engines, but we cannot confirm this. It may also be true for Defenders and Range Rovers with the same engine. Again we don't know.
NAS Discoveries have a digital readout for diagnostics. It is a black plastic box measuring approximately 1" x 2.5" x 3" with a red LED readout. It is found under the passenger seat facing backwards. It may be unclipped and moved so that the driver can see it.
This doesn't give nearly as detailed readout at the official test box, but it's better than nothing.
Fault Codes
Jump directly to the fault code:
02 12 14 17 18 19 21 23 25 28 29 34 36 40 44 45 48 50 58 59 68 69 88
General:
* The fault codes are given in order of priority. If more than fault exists, you have to clear the display before the next fault code can be displayed.
* Fault code 02 meas that the ECU has just been reconnected. Switch on the ignition to clear the display.
Clearing the display
1. Switch ignition on.
2. Disconnect serial link mating plug, wait 5 seconds, then reconnect.
3. Switch ignition off, wait for main relay to drop out.
4. Switch ignition on. The display should now be reset. If there are other faults, the next one will be displayed. Otherwise the display will be black
5. If there is more than one fault repeat steps 1 to 4, to clear each fault until the display is blank.
No LED's are on:
Good news; nothing is wrong. Either that or Mr. Lucas has struck and either the LEDs are burned out or the display isn't getting any power.
Code 29 - ECU memory check
If detected all other faults are unreliable and must be ignored.
Procedure:
1. leave battery connected
2. switch ignition off
3. wait for approximately 5 seconds
4. disconnect ECU plug.
5. reconnect ECU plug
6. switch ignition on and check display unit.
If fault code 29 is detected again, swap out the ECU for another one and retest.
Code 44 - Lambda sensor A - left bank
Code 45 - Lambda sensor B - right bank
If one of these fault codes is displayed check the wiring to that particular lambda sensor.
If both codes are displayed, the voltage supply to the heater coils of the sensors must be checked. Refer to test 26, continuity test procedure.
Distributor cap
Rotor arm
Coil
Pick-up (air gap)
Amplifier
Spark plugs
HT leads
Distributor cap
Code 12 - Airflow meter
Refer to test 19, continuity test procedure.
Code 21 - fuel tune select
Identifies that the tune select resistor is open circuit- refer to tune select resistor test.
Code 34 - Injector bank A
The display will indicate if the injector(s) are causing the engine to run rich or lean.
If the bank is running rich, check for - faulty injector wiring and connectors, stuck open injectors.
If the bank is running lean, check for - faulty injector wiring and connectors, blocked injectors.
Code 36 - Injector bank B
As code 34, except relevant to bank A injectors.
Code 14 - Coolant thermistor
Refer to test 14, continuity test procedure.
Code 17 - Throttle potentiometer
Refer to test 17, continuity test procedure.
Code 18 - Throttle potentiometer input high/airflow meter low
refer to tests 17, 18, and 19 of the continuity test procedure.
Code 19 - Throttle potentiometer input low/airflow meter high
Code 88 - Purge valve leak
refer to test 9 and 10 of the continuity test procedure.
Code 28 - Air leak
check for air leaks in the following areas:
o Hose, air flow meter to plenum
o Breather system hoses to plenum
o Brake servo hose
o Vacuum reservoir hose (fresh air solenoid)
o Distributor vacuum advance
o Hose, purge valve to plenum
o Injector seals
o Joint - bypass air valve to plenum plenum chamber to ram housing ram housing to inlet manifold inlet manifold to cylinder head bypass air valve hose
Code 23 - Fuel supply
check fuel system pressure, test 20 of continuity test procedure.
Code 48 - Stepper motor
check base idle speed- see setting procedure. Refer to tests 15 and 16 of continuity test procedure. Check road speed sensor- refer to test 25 of continuity test procedure.
Code 68 - Road speed sensor
Code 69 Gearswitch
refer to test 24 of continuity test procedure.
Code 58 Group faults 23/28
This indicates that a fault has been registered that is caused by the fuel supply or an air leak but the exact fault cannot be identified. Check all items outlined under codes 23 and 28.
Code 59 Fuel thermistor
Refer to test 13 of the continuity test procedure.
Copyright Dixon Kenner, 1995-2006. Last modified March 15, 2005.
Comments? Send mail to Dixon Kenner or Benjamin Smith
Site Designed and Created by Bill Maloney
Russ Wilson
Russ Dushin
Tom Tollefson
Steve Denis
Don Watson
Fixing It
Ted Rose's Buns
Andy Grafton
Old Jun 24, 2007 | 07:12 AM
Thanks for your help Mike. The codes are all cleared, and running fine.
I'm helping a buddy out with his '95 classic. Are these codes the same for '95, as well as the process of checking them?
Thanks again,
Cheers,
Glenn
Old Jun 24, 2007 | 10:12 AM
For all OBD1 vehicles so yes the 95 in the same.
Mike
ammonation
Jun 3, 2015 04:40 PM
dparham
Apr 17, 2015 02:54 PM
dparham
Apr 14, 2015 08:44 AM
FlyingZebra34
Feb 22, 2014 05:39 PM
sayeedA
Nov 15, 2011 11:02 PM
