Sponsored by: CARiD
Clutch Hydraulics confusion
Old Jan 17, 2016 | 01:37 AM
Lamar Latrell's Avatar
4th Gear
Default Clutch Hydraulics confusion
Hello all,
PUMA model Defender 2008.
Bit of a head scratcher here after replacing my clutch master cylinder, I've bled it and had no bubbles coming through for quite a few pumps, but now that I've topped up the reservoir and closed the bleed valve the clutch pedal will still fall to the floor and stay there - i.e. no spring return from the clutch itself.
I'm not losing any fluid or see any leaks.
The original problem displayed similar symptoms where the pedal would fall to the floor - but only after a fair amount of driving without using the clutch, and pumping a couple of times would get it working again.
It is now like this all the time.
(Master cylinder was a relatively easy/cheap 'try it and see' diagnostic.)
I'm wondering how I've made it worse? Or have I just forgotten some simple step in working with the clutch hydraulics?
My only thought is that there is still air in the line and depressing the clutch is compressing that instead of hydraulically activating the slave cylinder - but if I'm not seeing air in the fluid then ??
Any tips appreciated.
buttocks
Dec 31, 2014 12:53 AM
Patrick Duffy
Nov 26, 2012 08:48 AM
dhlair
LR2
Aug 20, 2008 02:04 PM
werldcup
May 12, 2008 12:01 PM
