Sponsored by: CARiD
code 1193
Old Oct 4, 2008 | 08:03 AM
kayaku's Avatar
Default code 1193
I have a enigine code 1193, called dealership and no one knew and their system was down. does anyone know of a website they can be looked up?
Old Oct 4, 2008 | 08:15 AM
kayaku's Avatar
Default RE: code 1193
Wow! Maybe everyone knows this already. OBD-Codes.com every land rover code. Now I found it but what the heck does- OXYGEN SENSOR HEATER CIRCUIT OPEN DOWNSTREAM mean? I may just try disconnecting the leads and clean the connections. Think that will work?
Old Oct 4, 2008 | 08:26 AM
First what model, year and mileage??
That code is indicating that both the rear 02's have their heater circuit open, which shold be closed when at operating temp.
Old Oct 4, 2008 | 08:58 AM
kayaku's Avatar
Thanks for the reply. It's a 98 disco, 92k miles. A guy at work said he saw a little blue smoke when i took off cold, I haven't seen it coming out of my exhaust. Does stink a little at start up. Not blow by, been watching my oil. maybe this sensor stuck open is the cause?
Old Oct 4, 2008 | 09:23 AM
No, not for what you are describing.
Smoke can be normal for a cold Rover cause they run so rich when cold.
I am not sure what is causing both to be running, could be they are getting tired but even more so it could be an ECU issue.
I would talk with your mechanic and see what he says.
Old Oct 4, 2008 | 09:32 AM
kayaku's Avatar
Maybe replacing them would fix it? Have check I'm sure their at least 100 bucks a piece. Emissions test will catch up to me soon, so I'll have to fix in the next few weeks. Think I'm gobbling up gas, I'm watching this tank full, I use premium.
Old Oct 5, 2008 | 09:26 PM
getplaning's Avatar
Rear sensor's only function is to monitor catalyst performance. They have no inputs that affect engine performance/fuel economy.
Clear the codes and see if they return. If it is a hard fault, the code will return as soon as you start the engine. If so, get out the wiring chart and do a little testing. At this age and mileage, it could very well be an O2 sensor.
csp
Jul 1, 2013 07:33 AM
Maytag
Jul 21, 2012 05:00 PM
sayeedA
Nov 15, 2011 11:02 PM
AK Rover
Jan 6, 2009 04:01 PM
kayaku
Sep 27, 2008 02:02 PM
