Sponsored by: CARiD
Codes, codes and more codes
Old Feb 9, 2016 | 02:41 PM
mambodave's Avatar
3rd Gear
Default Codes, codes and more codes
Hello, I did some searching, but didn't really find what i was looking for.
I picked up a 1999 DII knowing it was throwing codes. Temp sensor, MAF, and O2 sensor were the first ones. Replaced all of those, and all was well. I drove it around town today. All good. Until... I did a 20 miles interstate run at about 70mph, came off exit ramp and bad shudder while at stand still. Give it gas, smooths out. SES light didn't come on (but was on previously).
I plugged up the scanner and now have:
P0130, o2 circuit , bank 1(they were all just replaced)
P0300 random misfire
P0303 Cyl 3 misfire
P305 Cyl 5 Misfire
P0101 System too lean, bank 1
P1171 System too lean bank a and bank b
What in the world?? Something must be off, what do i check now? I don't see anything leaking around those cylinders (at least on the outside). I hadn't pulled the plugs yet, but wondering what else could be causing this.PO replaced the plugs and wires, that's all new. It seems to run better when its cold. The original issue was rough idle when cold. Once the Temp sensor was replaced, that issues went away, now it runs bad after warm at idle in gear.
Old Feb 10, 2016 | 07:30 AM
drowssap's Avatar
pull the plugs and check the wires on number 3&5, they are on the same coil pac.
on you o2 sensors disconnect then clean the connection and apply some dielectric grease, see if that helps.
also what brand o2's did you install?
Old Feb 10, 2016 | 07:37 AM
mambodave's Avatar
3rd Gear
All Bosch. PO said Wires are NKG, not sure on the coils but he did those also when he did the wires. Would make sense now on the coil for 3 and 5.
Old Feb 10, 2016 | 08:50 AM
drowssap's Avatar
i would start pulling the 3 & 5 plugs and see what they look like,
fouled, wet, carbon.
i would them swap the #3 & #5 wires and see if the miss fire follows,
if it follows, you have bad wires.
I too replace all my o2 with bosh and had trouble until i cleaned everything up,
you see any leaking engine oil like to run down the cable inside the connectors.
your scanner must tell you live imformation, what kind of reading are you getting on the o2 sensors?
any coolant leaks that you know of?
I would rule out everything before springing for a coil.
Old Feb 10, 2016 | 08:56 AM
mambodave's Avatar
3rd Gear
No coolant/oil leak .45 (so illegal value) on all of them except one, .59. I need to grab it when its warm and does it again to get actuals i guess. Ill pull the plugs and clean and grease the connectors and see what happens.
Attached Thumbnails Codes, codes and more codes-fullsizerender.jpg   Codes, codes and more codes-fullsizerender-2.jpg
thedudek05
Sep 26, 2013 02:43 PM
buick56
May 15, 2013 06:11 PM
Bryan H
Feb 12, 2009 10:59 PM
KeizerRover
Jun 1, 2008 12:06 PM
