Sponsored by: CARiD
coil spacer lift yes or no ????
Old Jan 6, 2013 | 03:13 PM
dobe1canobe's Avatar
Default coil spacer lift yes or no ????
i dont do any off roading the most is a dirt road or 1 foot of snow. now cost is an issue so i was gonna go with the coil spacer. my shocks are fine/newer disco sits normal. can i go with the spacers? thanks its a 2000 disco 2. 90k with 285/75/16 tire size.
Old Jan 6, 2013 | 03:32 PM
Spacers on old coil springs is not a good combination, you will get some lift but it will be top heavy, I would be to save up some money and do it right for a much better ride.
Whos' shocks are you running?
Old Jan 6, 2013 | 04:12 PM
Lots of people do it, stay 2" or under and you'll be fine.
Old Jan 12, 2013 | 02:20 PM
Albinorhino's Avatar
I put in some 2" spacers from terra-firma. I used to get slight tire rub when making sharp turns. This fixed that issue. I also replaced my shocks at the same time. I did reuse my springs tho.
I'm glad I did it.
Old Jan 12, 2013 | 04:52 PM
binvanna's Avatar
It's not clear why you want the lift. Do you run those tires now or you want to?
If you already have the tires, then there's apparently no need for the lift and it will just raise your roll center farther above the CoG and mess up the handling. It's true that people do 2" lifts and get away with it all the time but it's not true that their car handles better afterward. Most people are just lifting to fit tires and not to make the car handle better.
If you don't offroad then the tires don't move much in the wheel wells and you don't need a lot of clearance from a lift.
Frank4
Jun 30, 2012 07:13 PM
collin Barrows
Audio/Visual Electronics
Aug 21, 2011 12:47 PM
Spencerfitch
Feb 2, 2011 10:08 AM
malmberg
May 13, 2009 08:17 PM
tskeltonPGA
Jan 16, 2008 07:21 PM
