Sponsored by: CARiD
from coils back to air
Old Aug 21, 2014 | 07:35 PM
roverpdx's Avatar
Default from coils back to air
I may have been approaching this question from the wrong angle. if someone went from air suspension to coils and changed the slabs settings on a 2001 d2. When they went back to air suspension, What settings would need to be changed in the slabs settings with a nanocom or hawkeye? thanks
Old Aug 22, 2014 | 09:02 AM
drowssap's Avatar
you would need to change the program from coil back to sls simply done with a hawkeye, I don't know about the others
Old Aug 23, 2014 | 10:19 AM
roverpdx's Avatar
thanks drowssap. so I shouldn't have to mess with valve openings left and right inlet and outlet It handles all of that on its own? I have already switched from coil to air with nanocom, so, I think i must have a bad compressor?? thanks again
Old Aug 26, 2014 | 09:37 AM
drowssap's Avatar
check and see if someone unplugged the compressor
Old Aug 28, 2014 | 12:28 AM
roverpdx's Avatar
The compressor had swallowed some water from my last fjording adventure. evidently the intake line wasn't seated properly and the compressor seized and burnt the 30 amp fuse.
I got it pretty much working but now it bleeds off the airbags when the ignition is switched off.
CL500
19
Sep 29, 2015 10:44 AM
CL500
Apr 5, 2011 03:09 PM
1sttimediscoII
Jul 7, 2010 09:40 PM
99p38autobiograpny
Mar 6, 2009 06:49 PM
dalfier
Aug 30, 2007 02:20 PM
