Sponsored by: CARiD
Cold start problems v8
Old Oct 20, 2012 | 05:07 AM
utigarden's Avatar
3rd Gear
Default Cold start problems v8
Hi..!! I got a Disco -96 v8 efi and its impossible to start when the engine is cold and its around +-0 or colder outside. But if i put the motor heater on it will start. I have changed the temperature sensors but it didnt help. Any sugesstions what it could be...???
Old Oct 20, 2012 | 08:15 AM
Does your truck have an OBDII port under the dash? A scanner plugged in may show data from these sensors and others that could indicate one is way out of specification. Assume you mean turns over, has spark, has fuel pressure at the fuel rail, won't start and run. Perhaps unplug and re-seat MAF connector. Where are you that it is cold now, and is that 0 F or 0 C ? Battery voltage OK? Terminals clean and tight? Including those two in the front of the underhood fuse box? TPS sensor?
Old Oct 20, 2012 | 11:23 PM
What weight of motor oil are you using?
Old Nov 12, 2012 | 09:50 AM
utigarden's Avatar
3rd Gear
Mineral oil 10W/30
Old Nov 12, 2012 | 10:17 AM
Why mineral oil?
How about fault code numbers, how man miles on it, when was it last tuned along with 8 mm silicone wires, what octane and have you tested your fuel pressure before a cold start?
Old Nov 12, 2012 | 10:24 AM
utigarden's Avatar
3rd Gear
Hello I live in Sweden. I have had the car in approximately the nine years and it is in very good condition. Some bolts to the intake had been tapped up so it was leaking there. I replaced the gasket and made ​​sure everything was tight. Thought this would remedy the problem but it did not help, though it went much smoother after I changed the intake gasket. But cold start problems persisted. I have changed two temperature sensors, but it did not help. If it is at idle and I remove connector amount of air meter will start to go very bad, then it seams to be whole. But when the engine is warm it goes as it should, though I've noticed that if I drive very fast along the road so that passing speed 3000 rpm it starts to chop some perhaps related to cold start problems .... I have used a translation program if you wonder why the text looks weird ....
Old Nov 12, 2012 | 08:34 PM
Originally Posted by Disco Mike
Why mineral oil?
That just means regular motor oil.
Old Nov 12, 2012 | 08:39 PM
You need to check the fuel pressure, right side of the engine, towards the front is a schrader valve (tire valve) and using a fuel pressure tester check the fuel pressure.
Put the tester on, then try and start the engine, you need between 30 and 35 pounds per square inch.
Have a friend try to start it as you watch the gauge on the tester.
Also low quality fuel can cause hard cold starts as well as worn out spark plugs and leads.
A old dizzy can cause hard cold starts too.
Also switching to a 5w-40 or 5w-30 motor oil for the winter will help.
dynomite
Feb 14, 2015 04:33 PM
snads
Dec 6, 2014 02:42 PM
mattmo78
Nov 21, 2013 01:23 PM
pkppunk
Jan 26, 2013 07:05 PM
Lchop1.8T
Nov 29, 2011 08:31 AM
