Sponsored by: CARiD
Coolant flush
Old Oct 14, 2014 | 04:19 PM
acamato's Avatar
Originally Posted by drowssap
All I wanted to do is go to Auto Zone, pick up some coolant and fill it up. No mixing, diluting, etc...
and that is all you need to do, dump the old stuff by pulling the lower radiator hose and replace it with 50/50 green coolant
I agree, there is nothing wrong with using green coolant. If you flush your system with water, you should fill the system with 1.7 gallons (6.5L) of 100% coolant then top off with distilled water. You should fill the system this way because there will be water remaining in the block that will dilute the coolant you are adding. If you fill with 50/50 your end mix will be less than 50/50.
wannabe
Jan 24, 2011 10:42 AM
tsuami1
Jul 4, 2010 05:25 PM
Baylink
Nov 7, 2009 08:49 AM
tunernewb92
Jun 23, 2009 04:44 PM
puchungozback
May 26, 2007 12:26 AM
