Sponsored by: CARiD
Coolant Leak on 03 RR
Old Nov 26, 2008 | 07:37 PM
Young's Avatar
Default Coolant Leak on 03 RR
I recently had a coolant level low light come on about a month ago and i took it in and had the water punp replaced. Now i'm getting the same message and when i look under the truck the coolant is all running out hard from the center of the truck closer to the passenger side behind the front tire... It was making a hissing noise???? Any suggestions??
Old Nov 26, 2008 | 08:05 PM
Young's Avatar
Default RE: Coolant Leak on 03 RR
Size:  41.3 KBName:  DSC00481.jpg
Old Nov 27, 2008 | 08:12 AM
Can't tell from the pictures. By the way that green coolant shouldn't be used in your Rover, check your manual, I believe you are supposed to be running Dexcool.
Old Nov 27, 2008 | 01:55 PM
Young's Avatar
Ive checked the oil stick and no signs of any residue other than straight oil......but i did see a line that seems to be leaking....Looks like the line has a sensor that is attached to the end of it...Not sure what it is but in the pictures above its the picture to the right...That black hose/line that can be seen pluggd into something.
ZMonet
Jun 24, 2016 04:00 PM
MyRoversNameIsCarl
Aug 10, 2014 09:22 PM
nolabrooke
May 21, 2010 09:33 AM
lipadj46
Jul 8, 2009 07:41 PM
