Sponsored by: CARiD
Coolant queation
Old Jul 11, 2018 | 12:13 AM
Broncoguy27's Avatar
6th Gear
Default Coolant queation
Hi!!
i am looking at a 2002 discovery 2 with a 4.0 motor. It loses coolant and the head gaskets have been done. There's no white smoke from the exhaust, it's "burping" out the reservior. Could this be an air pocket, or is it the block? The truck is excellent cosmetically, and has old man emu shocks. The seller wants $600 for it, I'm not sire it's worth doing a motor in though. Any help would be appreciated. It's exactly the truck I want, but only if I can great it drivabt for a reasonable amount of money.
Old Jul 11, 2018 | 07:16 AM
WaltNYC's Avatar
How old is the head gasket job?
Coolant loss could be a leak and you'd see that on the ground.
If it is burning coolant the head gasket could need replacement (again) or it could be a slipped cylinder liner (though that is more prevalent on the 4.6 engines). And of course the block could be trashed. A pressure test would help narrow it down.
Old Jul 11, 2018 | 07:18 AM
6th Gear
Default Thank you
It never got on the road again after the head gasket job. It was done by the owner, not a professional.
Old Jul 11, 2018 | 09:33 AM
If he didn't have the heads machined its likely the head gasket leak is still present
Old Jul 11, 2018 | 09:36 AM
6th Gear
Default Thank you
I guess the head gaskets are about a grand to change, if it's head gaskets and he underside isn't rusty, I would love to get it.
Old Jul 11, 2018 | 09:37 AM
I think lucky8 has the headgasket kits with bolts for under $100. $200-300 to have the heads done at the machine shop. Fluids etc and a weekend of time puts you closer to $500
Old Jul 11, 2018 | 09:40 AM
6th Gear
Thank you
Jonathan C
Nov 15, 2012 10:22 AM
01d2Jeff
Jan 23, 2012 08:08 PM
Marty Mar
Jul 12, 2010 08:18 AM
jennifer
Nov 17, 2008 09:26 AM
Tastang
Nov 30, 2007 05:47 PM
