Sponsored by: CARiD
Cooling System Problems - Overview
Old Mar 17, 2014 | 11:18 PM
Indanao's Avatar
Default Heater - no heat?
Good day. Am wondering what the best way to clear out the Heater ( in case that's the issue ). Would it be to take the two hoses off the engine side of the firewall and shoot water in one of them with a garden hose?
Engine heat gage generally goes to half way and stays there. But, no heat just cold air. If idled after warm the temp. will slowly climb way up, still no heat. Lots of cold air blown out.
Old Mar 18, 2014 | 09:34 AM
drowssap's Avatar
you could try reverse flushing it that way, I have had limited success.
you do not say what type of vehicle it is, if it is a d2 there is no heater control valve so hot water should always be flowing threw the heater core, unless your out of coolant
ps. Also that gauge will always sit in the middle, until it'd to later.
Old Mar 19, 2014 | 06:58 AM
Indanao's Avatar
Default Heater Flush
Thanks. It's a D1, '95 Model.
No water leak on the floor or any indication of anything else happening.
Is there anything else that would cause it I wonder, e.g.: needs new core? It takes a long time to heat up to where the gage is showing 1/2
way up. ( Problem in Cold weather Canada, but I assume it because 300TDI is 2.5ltrs replacing 3.9ltr engine. )
Matt Humes
Jan 15, 2014 08:44 AM
Fivespddisco
Sights N Sounds
Apr 24, 2012 09:39 PM
Fivespddisco
Sights N Sounds
Jan 26, 2012 08:58 PM
jkeving
Apr 11, 2007 11:27 PM
esaycho
Feb 7, 2007 02:25 PM
