Sponsored by: CARiD
Cracked block or head gasket? [2004 Disco II]
Old Nov 29, 2015 | 07:22 PM
evoblade's Avatar
Default Cracked block or head gasket? [2004 Disco II]
I recently picked up this D2 from a mechanic. I bought it knowing the engine is probably screwed. When I changed the oil, the first bit out of the motor was brown water. Not good. Coolant in the oil. So I guess that means head gasket or cracked block? I don't know how to determine which one it is. Its not billowing white smoke.
I went for a brief ride. The squeal disappears at idle, but comes back as soon as you hit the gas. I thought I was taking a video of my first drive around the neighborhood, but turns out I wasn't. I did take a video after the second drive, just to hear the engine. It sounds like there is some kind of knock. This is with the engine hot.
After I shut it down there was a hiss from the upper part of the radiator (drivers side), so maybe I have a leak?
And after it cooled off I took of the coolant overflow bottle cap. The bottle was now empty. So either I pushed it all into the engine, or it leaks after the engine warms up. I say the last part because it doesn't seem to leak when cold. Either way, this engine seems pretty hosed but I would really like the opinions of the group.
For reference, here is my project thread: https://landroverforums.com/forum/di...-2004-a-73691/
Old Nov 29, 2015 | 09:29 PM
TOM R's Avatar
Guess video are private
Year of d2? 03/04 known for slipped liners
Old Nov 30, 2015 | 08:36 AM
evoblade's Avatar
My apologies. It should be fixed now. Please let me know if they are not working.
Old Dec 2, 2015 | 01:27 PM
Racer X's Avatar
Slipped liner (the tapping noise) + massive amounts of air in coolant = Likely a cracked block.
I'd put money on it, in fact.
Time to start looking for a new engine.
Old Dec 7, 2015 | 01:09 PM
evoblade's Avatar
Thanks for the input, it helps with the diangnosis.
rewi9d
Apr 27, 2020 05:46 PM
x1124x
Aug 12, 2017 09:25 AM
kmccarthy88
Nov 2, 2015 07:55 PM
Capital202
Apr 3, 2014 12:28 AM
37chambers
Oct 28, 2005 09:03 PM
