Cranking after sitting...
Greeting rover family!
As mentioned above... Any way I can safely turn the disco over without metal on metal contact from sitting for about 8 months? I'm running some fresh Rotella T 15/30 I believe in the Bay Area on an incline.
I've read that in some cars I can disengage the fuse to the starter and prep the motor by turning the key to the on position to squirt some oil with own pump... Sadly, I am not a mechanic but I do love my truck and have grown a LITTLE competant thanks to YOUTUBE. please advise!
Cheers,
Rich
Cheers,
Rich
A Simpler way is to open the oil cap , use an oil can with a flexible line , squirt some oil ,or try to ...get some oil onto the rocker area , then start , and let idle ,don't rev the engine !!! then try to get it to a level surface ..
this is not different to parking up for one week /one month ...... it take a few hours for the oil to cool and run back down.. and oil does not evaporate when car is parked anyway.....the oil pump will do its job...
if the truck has been sitting 8-months there is no way to start it up without metal on metal contact; unless you pressurize the oiling system.
the only way I see that happening is removing the oil sender unit and forcing oil in using something like a pressurized garden sprayer.
personally I agree with pulling the plugs spay the cylinder and crank it over with the plugs out until you see oil in the top end. reinstall the plugs and fire it up.
oiling your rockers is going to do nothing for your bearings, other than run down the oil return holes.
![Confused](https://landroverforums.com/forum/images/smilies/muBAORM.png)
So Cranking it without the plugs wont cause just as much friction/damage: YES; it does this because there is no compression.
so pre lubricating the rockers won't prevent the un-necssary cranking and extra work, THAT IS CORRECT
the oil is just going to run down the returns, plus how do you squirt oil in the other cover.
the rocker are the last thing to see oil, the bearings and rings are dry along with a good portion of the lifters have drained down,
you need to pressurize it from the bottom up.
seriously dude.
seriously dude.
I really appreciate all the help everybody. I'll definitely consider all the suggestions. I've tried squirting oil into the spark plug holes before since I've had to park her for another long period of time and it seemed to work. I was really hoping that there was a way the rig can do it on its own by removing the fuel pump fuse and cranking it that way without removing the plugs. Now, I totally see how the marvel mystery is needed to further avoid the "heavy metal". Thanks a lot gents!
seriously dude.
seriously dude.
drowssap (04-23-2015)
