Sponsored by: CARiD
Cruise control issue.
Old Nov 26, 2016 | 09:46 PM
eskiltell's Avatar
Default Cruise control issue.
Hello all,
I got a disco 2 se7 209000 miles. everything works except the CC. I replaced the cracked vac hose. the dash button works and I can hear a click behind the glove box when I pull the res button but nothing when I pull the set button. I've looked for the vac hose from the break pedal as recommended, but I can't find one. not sure of any other tests I can do so any info will be appreciated
Old Nov 27, 2016 | 09:55 AM
number9's Avatar
Owner's Manual:
Press the ‘SET +’ switch to set the vehicle
speed in the system's memory.
Have you tried pressing set?
Old Nov 27, 2016 | 09:59 AM
eskiltell's Avatar
Originally Posted by number9
Owner's Manual:
...yes
Here's the page from the manual.
The picture shows to pull the buttons towards you
Old Nov 27, 2016 | 10:43 AM
number9's Avatar
......Yes you are correct, pulling is how the buttons are pushed. Please excuse my brain fart.
Old Nov 27, 2016 | 10:44 AM
eskiltell's Avatar
no worries,
got any clues as to what my issue is then? hahaha
Old Nov 27, 2016 | 10:55 AM
eskiltell's Avatar
no worries,
Old Nov 27, 2016 | 02:33 PM
number9's Avatar
no worries,
Appreciate your understanding.
Others likely to have suggestions and I'll try taking a look at it later when time permits.
Do you have copies of the Maintenance and Electrical manuals from the RAVE? They are helpful in describing the relatively simple operation.
land rover service factory manual RAVE download land rover resource, service manual, workshop factory manual, download, rave, vehicles including discovery, series, defender, range rover, freelander, LR3, Handbooks, Catalog, Catalogue, Land Rover Inte
Old Nov 27, 2016 | 03:44 PM
ihscouts's Avatar
Vacuum diaphragm and the vacuum pump. Check the diaphragm for leaks (cracked) and vacuum pump for operation (seized). Real tough stuff here........ Those are the most commonly bunged up components wether it's a DII or a D1, same same.
Old Dec 1, 2016 | 04:12 PM
eskiltell's Avatar
so I done fixed it. new vac hoses and took apart the little motor and gave it a good clean with a quip. thanks everyone
Old Dec 1, 2016 | 04:35 PM
number9's Avatar
Glad to hear it's working without too much pain/expense. One of those systems I don't like to be without.
