Sponsored by: CARiD
Cruise control vacuum line
Old Feb 12, 2016 | 01:11 PM
Roverfarmer's Avatar
Default Cruise control vacuum line
Pretty new to working on Rovers. I have a v8 97 discovery that I picked up for a few hundred bucks. I'm playing around under the hood and noticed that the vacuum line for my cruise control is unplugged and cracked. I mostly use the rover for driving around the ranch and it doesn't see much highway use. Can I just forget about the cruise control? Do I need to seal off these lines or just forget about them?
Old Feb 13, 2016 | 01:39 PM
Gripen's Avatar
Should be fine, though I would seal off the ports to prevent unwanted debris from getting in. If you are so inclined, getting a short length of vacuum tubing to replace the cracked line is fairly inexpensive.
Old Feb 17, 2016 | 04:18 PM
hrhoward's Avatar
Yeah, should be fine. Best I can tell, the cruise control uses a separate little electric vacuum pump. It is located behind and below left headlight underneath the jack.
archaeology_student
Oct 1, 2013 04:24 PM
mj_duell
Oct 19, 2011 03:43 PM
JBeezy53
Feb 16, 2011 07:18 PM
flacsrover
Sep 4, 2010 11:19 PM
Rover Chris
Jan 7, 2010 09:17 PM
