Sponsored by: CARiD
D1 Transfer Case Swap
Old Oct 22, 2020 | 04:20 PM
disco96sd's Avatar
Default D1 Transfer Case Swap
Anyone know or have a sense what the apx. shop time is to pull out a transfer case in a D1 and install another unit ?
Thanks
Old Oct 23, 2020 | 12:31 PM
WaltNYC's Avatar
The labor times manual can be found in the google drive. For a Defender it is 5.3 hours. Very likely to be similar for a D1.
Old Oct 24, 2020 | 07:48 AM
Shiftonthefly1's Avatar
I assume you're using this as a base for what you're being charged at a shop? Not asking how actually long it takes to do yourself?
Old Oct 24, 2020 | 08:18 AM
disco96sd's Avatar
yes to check a shop's time
Thanks
Old Oct 24, 2020 | 09:57 AM
There I can't help ya. But if it's any more than 5-6 hours I'd say you need to negotiate that. Being familiar w the vehicle really speeds up the time. I can do a swap in about 2-3hrs. If a shop isn't familiar with it I could see 5-6hrs
Old Oct 24, 2020 | 10:08 AM
disco96sd's Avatar
thanks guys ! - I will use this great info to discuss with the shop
Old Oct 29, 2020 | 07:41 PM
disco96sd's Avatar
it appears that the breather hose on top of the transfer case slipped out of the holding bracket - it ended up being on the exhaust and melted shut - forcing the gear oil to spray out thru a gasket and coat the bottom of my Disco - thus no drips or leaks on the drive - and running it dry and causing it to break the bearing and finally seize the gears up - what a mess that was - I was saved by Matt Browne at Overland Engineering in the Portland ME area
Tony Luna
Feb 1, 2018 03:08 PM
conrad1468
Dec 15, 2017 08:13 AM
xargon15
Mar 10, 2015 05:17 PM
britishtoys
Dec 3, 2014 10:23 AM
alex of minnesota
Dec 13, 2006 08:41 PM
