Sponsored by: CARiD
D1 transfer case
Old Nov 29, 2014 | 02:07 PM
britishtoys's Avatar
Default D1 transfer case
Hi, at the risk of being redundant; I need to replace the transfer case on my 95 Disco w/auto transmission. I've looked through the forums on here and can't find a clear answer to what other years/models use the same t-case that i can use. Wrecking yard guy says only a 94-95 Disco t-case will work, hard to believe that, a lot of other trucks use that LT230 case.. thanks for any info..
Old Nov 29, 2014 | 04:04 PM
FantomRover's Avatar
Never take advise from a wrecking yard guy...cause pretty soon he'll just say it's not worth fixing a landy and to just junk it. Any year lt 230 will fit. You have to watch out for different high range ratios though cause there are 6 or 7. I have an lt230 that I pulled out of my 98. It works great,I just went for a lower gear ratio so I got a newer transfer case. It is for sale if you are interested
Old Dec 3, 2014 | 12:30 AM
Thanks. i got a complete tranny with transfer case so i will just swap the complete unit. Are all the ZF tranns the same? the guy i bought it from wasn't sure what year it came out of, it looks a lot newer than mine
Old Dec 3, 2014 | 10:23 AM
As long as it's from a d1 it'll fit. The d1 uses a zfhp22 where as the d2 uses a zfhp24. The d2 is more electronical than the d1
imag
May 12, 2006 07:59 PM
adowgiert
Aug 27, 2005 04:53 PM
garnstar
Aug 3, 2005 01:45 AM
Loose_Screws
Jul 22, 2005 12:13 AM
Smokeyone
Jun 4, 2005 03:11 AM
