Sponsored by: CARiD
Defective new master cylinder????
Old Nov 15, 2008 | 09:43 AM
Shaymer's Avatar
Default Defective new master cylinder????
I had bake issues. Feedback from issue posted indicated a blown master cyl. Went to 2 brake shops... same diagnosis. Bought a remanufactured master cylinder from Autozone. Read up on how to install and did it.
Problem is that no matter how many times I bleed the front brakes, they're useless after a few miles. Back brakes are fine. No problems, did them right. But when I bleed the front brakes, the keep spitting out a combo of fluid and air. I'm not leaking fluid and both front brakes show the exact same symptoms, so...
What's the issue here?
My thinking is that there's a problem with the FRONT chamber of the master cylinder, because when I primed them, the rear chamber started circulating fluid out of the port after only a few cranks, but I couldn't get fluid to flow out of the front chamber consistently. I must have cranked that thing each way 50 times.
Am I missing something? Is the master not the problem?
I think I got a defective remanufactured master cylinder, but I wanted smarter opinions.
Thanks.
Shamus
Old Nov 15, 2008 | 11:15 AM
Default RE: Defective new master cylinder????
If you bled the master cylinder prior to installing it and it doesn't work, it is probably a bad rebuild. Remember to use DOT 4, ONLY!!
Mike
Old Nov 18, 2008 | 12:42 PM
Shaymer's Avatar
I bled the master... not sure if I bled it enough. The rear cylinder was fine. The front seemed strange. I cranked it over and over and wasn't getting a consistent flow. I'm going to rip it out and prime it again. If I can't prime it in two attempts, yet the back primes no problem, I think its got to be a bad reman.
Thanks,
Shamus
Externet
Jan 17, 2013 05:12 PM
ljdiscovery
Feb 9, 2011 03:59 PM
DooDer
Jan 3, 2010 11:38 AM
sharp
Apr 29, 2009 09:05 AM
BostonBB
Oct 9, 2007 05:32 AM
