Sponsored by: CARiD
Defender 90 no start issue
Old Nov 12, 2020 | 06:08 PM
Jmec75's Avatar
3rd Gear
Default Defender 90 no start issue
Currently have the strangest issue ever I have seen. Finishing up a chassis swap and truck was running prior to new chassis. Now have a no start condition.
Now the strange part. Truck will only start with the fuel pump unplugged, and gauge showing 0psi at the fuel rail. Fuel system was rebuilt during the swap including fuel pump, regulator, filter and all new lines. No CEL at this time.
I am at a loss for what coulding be causing this. Hopefully someone has some insight. Thank you in advance for any help.
Old Nov 12, 2020 | 06:36 PM
TexasLandmark's Avatar
Does it always crank(turn over)?... but actually starts when fuel pump unplugged?
Old Nov 13, 2020 | 06:33 AM
Jmec75's Avatar
3rd Gear
It will always crank strong. Will only start will pump unplugged, and strangely there can be no pressure showing at the fuel rail. If these parameters are correct engine runs perfect.
Old Nov 13, 2020 | 07:39 AM
Jmec75's Avatar
3rd Gear
Update. Out tinkering with the truck this morning and discovered constant ground at all eight injectors. Leaning towards ecu failure, as I have unplugged ecu and ground went away. Get out wiring schematic now, any input to help with my sanity greatly appreciated.
RJ5
Sep 24, 2019 09:59 PM
TC.kenya
Defender
Jul 10, 2011 01:56 AM
zopa
Nov 27, 2010 03:26 AM
gdtna
Defender
Jul 11, 2009 04:38 PM
Mountainman
Nov 12, 2007 09:59 AM
