Sponsored by: CARiD
DII rear lowers at night AT EXACTLY 9:15pm
Old Sep 17, 2014 | 08:58 AM
norstar's Avatar
3rd Gear
Default DII rear lowers at night AT EXACTLY 9:15pm
The last few nights the rear/driver side of my 99 discovery II lowers. When I start the truck it raises to normal levels. I have researched this issue and found that it may be the air bag but the thing that throws me... It happens every night at exactly 9:15pm. Truck sits at work all day with no problems. get home at 5:30. Go out at 9:15 and watch the rear lower.
??? should I attempt to replace the air bag or is there something else I am missing?
Old Sep 17, 2014 | 11:20 AM
acamato's Avatar
Are you sure its not lowering 3:45 after you turn it off?
You can swap the bags and see if the drop follows the bag or stays on the left side.
Old Sep 17, 2014 | 03:31 PM
norstar's Avatar
3rd Gear
Yeah... last two nights, right at 9:15PM
Old Sep 18, 2014 | 07:31 AM
OffroadFrance's Avatar
It's probably the SLS rear air bags suspension leaking or the compressor is defective or the NRV isn't working properly between the compressor and air suspension or it may be a case you need these guys
Old Sep 19, 2014 | 09:36 AM
acamato's Avatar
Did you spray the bags with soapy water to check for leaks?
Here is a good overview of the SLS system & troubleshooting:
Disco 2 Disco II Air suspension – the definitive guide! - Land Rover Zone
MoShadeTree
Sep 7, 2013 06:50 PM
rcharrette
Feb 22, 2013 09:49 AM
hattoe
Sep 8, 2010 02:39 PM
llPANCHOll
Apr 22, 2009 02:53 PM
brandon4589
Jan 2, 2009 09:47 PM
