Sponsored by: CARiD
Disappearing coolant
Old Sep 28, 2020 | 12:04 PM
Frank Gordella's Avatar
Default Disappearing coolant
Recently, on my 04 disco, the coolant tank will be full to correct fill level at start but after driving, expansion tank looks empty. Engine temps stay perfectly normal. No visible leaks or smell of coolant, no white smoke. When I open the full cap on the expansion tank, fluid then fills from the lower hose on the tank - like it’s under a vacuum.
It feels like I have air trapped in the lines but when I open up the bleeder valve, I get coolant coming out immediately.
Any ideas what’s going on?
Old Sep 28, 2020 | 01:59 PM
[QUOTE=Frank Gordella;744433]Recently, on my 04 disco, the coolant tank will be full to correct fill level at start but after driving, expansion tank looks empty. Engine temps stay perfectly normal. No visible leaks or smell of coolant, no white smoke. When I open the full cap on the expansion tank, fluid then fills from the lower hose on the tank - like it’s under a vacuum.
Here’s the setup. Inline thermostat was installed by previous owner. I’ve never had any issue with it, so far.
Wheelspin
Aug 12, 2020 12:02 PM
dougn
Mar 2, 2020 11:35 PM
aguison
Nov 26, 2012 08:33 AM
brooksa
Jan 17, 2009 03:09 PM
